Discussion topic: Mr Ali
Message posted on 14 Feb 2024 12:41 PM
Mr Ali
My sky Q box switches on but my remote doesn't work on it I've checked the remote on my cousin's box and it works fine do I have a faulty box or is it some other issue
Message posted on 14 Feb 2024 01:01 PM
Re: Mr Ali
Try removing your batteries and replace them with new ones.
also check the settings to do a reconnection to your box go to sky settings set up amd remote contol. See what remote control you have there and follow the instructions
Message posted on 14 Feb 2024 02:09 PM
Re: Mr Ali
@Ali1 if the remote works on another box sounds like the remote is fine Have you tried rebooting your main Q box ie
then trying the remote again or repairing the remote
To re-pair your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
