Discussion topic: Moving tv
This message was authored by: Elaine+1973
Moving tv
I'm looking to move my tv but the cable from the sky dish to box isn't long enough can I get an extension cable and if so what am I looking for please?
Re: Moving tv
@Elaine+1973 yes you can buy extension cables from many places see below here are some on amazon
https://www.amazon.co.uk/s?k=satelitte+extension+cables&crid=2MI67AZHJCX61&sprefix=satelitte%2520ext...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: bob1234
Re: Moving tv
@Elaine+1973Just search on Amazon / ebay for "satellite cable extension" and chose the length you want.
Re: Moving tv
Hi @Elaine+1973
Just bear in mind that you need two cables with the necessary two F connector fittings..
Some come as as a pair or as a twin (shotgun) cable and include the two female F connectors.   However some are single cables where you need two.
