Discussion topic: Moving home
Message posted on 19 Sep 2024 03:28 PM
Moving home
Message posted on 19 Sep 2024 04:10 PM
Re: Moving home
Is this for a private dish or communal setup?
Message posted on 19 Sep 2024 05:16 PM
Re: Moving home
Hi..
It's a terraced house, but communal dish
Message posted on 20 Sep 2024 10:26 AM
Re: Moving home
Anyone else help?
Message posted on 20 Sep 2024 10:33 AM - last edited: 20 Sep 2024 10:36 AM
Re: Moving home
Hi @CraigScotland It sounds like you want your management company to move your sockets. As it is a communial dish, there is nothing that Sky can do. Your only option is to do what you don't want to do, run the extension cable around your room.
Note, if you only want HD (no UHD) then you could leave the Main box by the socket, and then use a Mini box connected to the TV.
Message posted on 20 Sep 2024 10:37 AM
Re: Moving home
Would sky stream be any good instead...if I could switch
Message posted on 20 Sep 2024 10:39 AM
Re: Moving home
@CraigScotland wrote:Would sky stream be any good instead...if I could switch
Hi @CraigScotland No idea, this is the Sky Q community.
Message posted on 20 Sep 2024 10:44 AM
Re: Moving home
I'm not sure I even use uhd...so might be an option just for mini box
Message posted on 20 Sep 2024 05:01 PM
Re: Moving home
@CraigScotland you could try booking a home move with sky - but be sure they understand it is a communal dish - they may be able to move the incoming cable.
