4
This discussion topic has been answered Discussion topic: Move main 2tb box
This message was authored by: Nig+c
Move main 2tb box
I have sky q and I have a quad lnb.
there were 2 short cables coming from the lnb that previous cables were plugged into. So I connected some new cables to that an ran them to a new location but when I connect to the sky 2tb I get no signal.
What have I done wrong? Do I need to go into service menu and change any settings?
This message was authored by: nigea99 Answer
Re: Move main 2tb box
hi @Nig+c
If 2 outputs were connected and working with SKY Q then it will be a Hybrid LNB not what is normally called a Quad LNB (Quad LNBs typically have 4 'universal' outputs none of which work with SKY Q)
As @PandJ2020 indicates with a Hybrid LNB only one set of outputs, output the wideband signals that SKY Q needs  - the other set being 'universal' outputs as used by SKY HD, Freesat TVs, & older Freesat boxes
Thus you cannot just move the box without changing the connections over at the LNB
Was a Sky HD box previously plugged into those cables?
Quad LNB's have 2 pairs of outputs, 1 set for Q and 1 set of legacy.
Avatar for Nig+c
Yes. Very likely was beforehand.
So I'm best going back to fish and swapping g at source?  Or can I do it an alternative way
thanks
Avatar for Nig+c
Go back to dish* 😂
hi @Nig+c
