Discussion topic: Move Sky Q Box rooms, external wire required
This message was authored by: JTwed
We have moved the TV to another room, require the cable pulling out the current wall then re-drilling through another external wall to the new location of the Sky Q box. Please can someone help, i have tried calling, the auto response doesn't really cover this and neither does the virtual assistant. Thanks in advance for your help
Re: Move Sky Q Box rooms, external wire required
@JTwed
You will have to persevere on the phone to arrange this. Sky charge about £65 for this service.
Avatar for JTwed
Can i action it myself or 'must' it be done by sky via T&Cs or is it there preference to action please?
Hi @JTwed
No reason why you cannot do this yourself if you are capable and competent .
This message was authored by: Doc5907
@JTwed
Alternatively you can get a local satellite installer/electrician to do the job. I say this as you have to know what you are doing when drilling walls in terms of pipe and cabling locations. If your confident then go for it.
Sky Q 1TB UHD
LG TV
Sky Mobile
