This discussion topic has been answered Discussion topic: More than one remote
Message posted on 18 Jun 2024 07:39 PM
Can sky Q have more than one remote control
Message posted on 18 Jun 2024 07:48 PM - last edited: 18 Jun 2024 07:50 PM
Yes you can use more than one remote with any SKY Q box but only one can be used in bluetooth mode & thus for voice control.
The others use infrared only
If you want more than one to control the TV it can be done but rather convoluted.
You first pair the one(s) you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
Message posted on 18 Jun 2024 08:15 PM
Re: More than one remote
Thank you both remotes working perfectly
