Discussion topic: Missing tv channels
This message was authored by: DM28
Missing tv channels
I'm having trouble lots of my channels are coming up with the message no satellite signal and no Netflix on the extra box I've been having issues for a week or more now I've reset the WiFi and the sky q box, the sky dish has been up 15+ years wondering if their is a issue with it
regards D Mullins
Re: Missing tv channels
@DM28  Your post has been moved from the broadband forum as a No Satellite signal issue is not a broadband related issue
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
...but will probably need an engineer visit to check the dish/LNB.
@DM28
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
