Discussion topic: Missing icons on YouTube
This message was authored by: Chey1
  • Hi Guys,
My mini sky q box is always freezing and when it froze whilst watching YouTube I switched it off and turned it back on. Now all I'm seeing on you tube is the search and homepage and setting options, I've lost music, subscriptions, history etc. Has anyone else had this problem and if so how did you manage to resolve? Checked the living room box and still not showing these tabs so unsure what's happened.
Re: Missing icons on YouTube
@Chey1 wrote:
  • Hi Guys,
Hi @Chey1
Reboot the mini as above.
Avatar for Chey1
Thanks, tried it still but still not showing. It's working fine on my phone but just not on the sky box.
Hi @Chey1
Have you tried refreshing the Apps in the main Q box Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Avatar for Chey1
Tried refreshing, logging out and back in the same. Hopefully it'll work tomorrow. Just called my mum and all of hers are showing on her sky so guess it's just a problem I'm having as usual with sky :(.
Just unsure how it disappeared seconds after, I've tried researching and it only speaks about the mobile app rather than TV/Sky box apps. Would be great if I could attach a pics for others to see what I mean is wrong. Literally the gaming, movies and all others have just gone..
Thanks for your help!
Avatar for Chey1
It's reappeared now 🤷🏾‍♀️
