Discussion topic: Missing channel 415
Message posted on 15 Oct 2024 11:28 AM
Missing channel 415
I can not receive channel 415 Sky sports racing. It tells me something is wrong with signal. This is wrong as all other channels are there. I have restarted & rebooted. Tried everything. I pay enough money to you guys
Message posted on 15 Oct 2024 11:51 AM
Re: Missing channel 415
Not 'us guys'. We are customers like yourself.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 15 Oct 2024 11:55 AM
Thanks Daniel,
1st time on this. Wasn't sure who responds. No humans in sky anwering me. Thanks for your advice.
