7
This discussion topic has been answered Discussion topic: Missing bbc1
This message was authored by: TomC6
Missing bbc1
Having trouble with bbc1 hd south. Screen keeps dissolving, then ok for a minute, then blank screen, back to dissolving again.
This message was authored by: xenon81 Answer
Re: Missing bbc1
Are you in the BBC One South region? BBC One South and Sky Mix are broadcast on the same frequency so it seems that your dish may be slightly out of alignment. The best thing to do is contact Sky so they can book an engineer visit.
Re: Missing bbc1
Is this on Sky+, Sky Q or Sky Glass or Sky Stream ?
Avatar for TomC6
Re: Missing bbc1
It's on Sky plus, also same problem on Sky Mix HD
Re: Missing bbc1
I have moved this to the Sky+ forum as you had posted this in the Sky Go one !
Avatar for TomC6
Re: Missing bbc1
Sorry, the box is Sky Q
Re: Missing bbc1
@TomC6
Are you seeing an error message on screen? What have you tried so far?
(your duplicate thread has been removed as you have this one)
Avatar for TomC6
Re: Missing bbc1
Only unplugged and re plugged the power, it no luck and no message
Re: Missing bbc1
