Discussion topic: Minibox won't work
This message was authored by: Sallyann1
Minibox won't work
Controller won't connect to mini box, mini box won't recognise it
Re: Minibox won't work
Hi @Sallyann1
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
