Discussion topic: Minibox problem
Message posted on 04 Feb 2024 11:53 AM
Minibox problem
My main sky TV Sat's you don't have subscription for sky q mini box
I never asked for this to be removed?
Message posted on 04 Feb 2024 11:59 AM
Re: Minibox problem
My main sky is working
My sky q minibox is not
It Says I do not have subscription but I never cancelled it
Message posted on 04 Feb 2024 12:05 PM
Re: Minibox problem
Hi @Joy+Heather
Try a Reset Settings in the main Q box hidden menu.
