Discussion topic: Minibox issue
Message posted on 27 Aug 2023 09:40 AM
Minibox issue
My Sky Q minibox has started freezing on all channels. There are no reported problems in the area. Any fixes without calling an engineer please?
Message posted on 27 Aug 2023 10:07 AM
Re: Minibox issue
Hi @Nick300361
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
