Discussion topic: Mini sky q not working
Message posted on 01 Mar 2025 04:16 PM
Sky Q mini box is frozen and there is no output signal. Box won't reset.
Message posted on 01 Mar 2025 04:54 PM
Re: Mini sky q not working
when you switch it on do you get any lights coming on ?
does it do anything if you press and hold the reset button on the back until the red light on the front flashes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Mar 2025 05:41 PM
Yes we do have lights
light just goes to amber
Message posted on 01 Mar 2025 06:06 PM
hi @Ian6661
Have you checked that the remote is working (replacing batteries if necessary) ?
To check press the ? button & the red led above the SKY logo button should flash
If the remote is working as above then:
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 01 Mar 2025 06:34 PM
Hi @Ian6661
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 02 Mar 2025 02:26 PM
I have the same issue on my minis - main box works fine! Is there a software issue.
