Discussion topic: Mini sky Q box
This message was authored by: Cieves
Mini sky Q box
My mini sky Q box won't connect to my tv
Re: Mini sky Q box
You need a HDMI lead?
Re: Mini sky Q box
Hi @Cieves
Reboot the mini as above.
