Discussion topic: Mini boxes will not coonect
Message posted on 30 Jul 2024 06:37 PM
Our main sky box is Working ok
we have 2 mini boxes in the house that will not connect for the last 2 days can you help
Geoff Pardoe
Message posted on 30 Jul 2024 06:55 PM
Re: Mini boxes will not coonect
Please answer my question
Message posted on 30 Jul 2024 06:57 PM
Geoff Pardoe
Hi @Geoffrey72
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
