Discussion topic: Mini boxes not working
Message posted on 26 Sep 2023 07:57 PM
Mini boxes not connecting to main box all mini boxes showing mr104 error.
nothing wrong with main box or Wi-Fi from what I can see
Message posted on 26 Sep 2023 08:01 PM - last edited: 26 Sep 2023 08:03 PM
Re: Mini boxes not working
Hi @Caz007
First try rebooting the main Q box and then when this is completely back up and running reboot the minis one at a time starting with the one nearest to the main Q box.
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the nearest mini to the main Q box. Also when try to connect the furthest mini you can use the previously connected first one if nearer than the main Box or the Sky router.
