Discussion topic: Sky Q Box with Red light on. Has a mind of its own and seems to be stuck on the ‘ok’ button.
This message was authored by: Paul82
Sky turns on and works, however when watching something it's like someone has there finger on the 'ok' button bringing the information bar up constantly and making it impossible to do anything on sky.
it's not the remote as took the batteries out and still did this, and it's. It the TV as when we turn the sky box off am able to watch Netflix etc.
Re: Sky Q Box with Red light on. Has a mind of its own and seems to be stuck on the ‘ok’ button.
Hi @Paul82
Avatar for Paul82
Level 0 icon
Thanks for the reply.
I have done this, all recordings wiped etc but after about 2 minutes back to having a mind of its own 🙃
Best to contact Sky for an Engineer then @Paul82
