Discussion topic: Mini boxes not working.
This message was authored by: Berni211056
  • Hi. Two out of three of our mini boxes are not producing a picture. Can you please assist? I've followed the on screen instructions several times. Look forward to hearing from you.  Kind regards. B. Williams.
Re: Mini boxes not working.
Hi @Berni211056
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
To help with your minis try the following:-
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the mini nearest to the main Q box.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
When connecting the other minis you can use a previously connected mini for WPS if it is nearest.
