Discussion topic: Can’t download on demand. I have done a system update….twice
Message posted on 18 Jun 2023 04:45 PM
Can't download from anything.
wveytging else works fine.
Tied to call sky and get sent here and then hung up on.
Getting so frustrated.
No offence to people posting but I'm not paying all this money to have people give their opinions on what's going on. I want to speak to someone and get it sorted .
Message posted on 18 Jun 2023 04:48 PM
Re: Can’t download on demand. I have done a system update….twice
wveytging else works fine.Tied to call sky and get sent here and then hung up on.
@Vowlesy1984 are you a new customer ? if you are then Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Jun 2023 04:49 PM
Thanks but I have UHD.
Message posted on 18 Jun 2023 05:01 PM
@Vowlesy1984 so are you a new customer ?
Message posted on 20 Jun 2023 06:29 AM
Been with sky for 15 years
Message posted on 20 Jun 2023 08:41 AM
Hi @Vowlesy1984 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 20 Jun 2023 10:37 AM
Hi
Known issue
See this thread, same issue. though mine started working again.
https://helpforum.sky.com/t5/Sky-Q/Downloads-not-downloading/td-p/4234000
