Discussion topic: Mini boxes not working since adding Netflix
Message posted on 05 Jan 2024 09:43 PM
Had sky add Netflix 2 hrs ago to my acct now our mini boxes aren't working
Message posted on 05 Jan 2024 09:47 PM
Re: Mini boxes not working since adding Netflix
Hi @Evie30
Reboot the minis as above. Start with the one nearest to your main Q box.
