Discussion topic: Mini boxes not working says technical fault
This message was authored by: cymru1964
Message posted on 12 Aug 2023 10:54 AM
Mini box not working
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Aug 2023 11:46 AM
Re: Mini boxes not working says technical fault
@cymru1964 Have you tried rebooting your main Q box ie
then
reboot your mini box
