Discussion topic: Mini boxes cannot connect to main sky q box
This message was authored by: Allan+Conybeare
Over the last couple of weeks my set up has stopped working correctly. The main box is working as expected, all connected and healthy.
Every couple of days when I turn it on usually in the evening. The mini boxes (got 2) say that they cannot connect to the activation server. I follow the instructions. to reset including restarting the main sky Q box, wait then try to reconnect the minis they then say that they cannot find the man sky q box.
At this point I usually give up and do something else. In the morning I turn the tv on again and they are working again.
I would appreciate any help I really want this resolved.
This message was authored by: Greenfingers001
Re: Mini boxes cannot connect to main sky q box
Hi there @Allan+Conybeare , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Lisa-P1987
Thanks for chatting to us @Allan+Conybeare . Unfortunately, there was no further response on the chat in 48 hours, we are still waiting to help you. If you need our support let us know and we can re-escalate to our chat team. Your chat has been closed now. Thanks
Lisa - Sky Tech Team Expert
Avatar for Allan+Conybeare
Hi Thanks. I've not experienced the problem for a couple of days. If it does I will follow the advice I received. If it doesn't work I'll reopen the query.
Hi, in case this impacts anyone else. The issue did recoccur and I followed the instructions provided by the guru and everything was okay and reconnected however I'm in the process of switching broadband providers and have had two routers running simultaneously which seemed to be causing some conflicts. Since I turned the old one off I've had no further issues.
