2
This discussion topic has been answered Discussion topic: Mini box
This message was authored by: Magsm
Mini box
Mini box is not mirroring the same as main box aps are not there or Netflix and all the others that are included
This message was authored by: Laing1 Answer
Re: Mini box
@Magsm you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
It can take up to 24 hours for this to work
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Mini box
Have you checked software versions are the latest?
https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Re: Mini box
