Discussion topic: Mini box
This message was authored by: Brad39
Mini box
2 of my mini boxes have stoped working. I have tried all the reset guides and think they need replacing
Re: Mini box
Hi @Brad39
First thing to try is to swap with a working one to see if it is a location issue.
Then make sure the minis are correctly connected.
Reboot the main Q box and then when this is completely back up and running reboot the minis.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini.
