Discussion topic: Mini box
Message posted on 29 Jun 2025 09:09 PM
Mini box
My mini box keeps not working and Iv tried resetting It, who should I contact
Message posted on 29 Jun 2025 09:20 PM
Re: Mini box
@Allyally wrote:My mini box keeps not working and Iv tried resetting It, who should I contact
Hi @Allyally
There are some pages to help with troubleshooting and then ordering a replacement box.
Here's a link. Hope it helps (I realise you aren't "stuck in standby" but the guide should still help)
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 29 Jun 2025 09:43 PM
Re: Mini box
Hi @Allyally
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
