Discussion topic: No satellite signal
This message was authored by: NathanBurns
No satellite signal
No signal it's Also coming up with Technical Fault
Re: No satellite signal
hi @NathanBurns
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Avatar for NathanBurns
Level 0 icon
I've done All that I've turned TV off 3 times and still coming up with no signal and a Technical Fault
As mentioned, if you have your own dish that link should take you to a link to book an engineer
Turning the TV off won't affect anything.
Do you mean the Sky box?
This message was authored by: Lau79
Having same problem here too
Also see post 2 then
