Discussion topic: Mini box
This message was authored by: Simonjj7
Mini box
Our mini box won't connect to the internet now . We have never had a problem . I know their has been major issues . We just have a blue screen saying about connection but it won't let us press anything no settings etc
This message was authored by: Steph+H
Re: Mini box
Where have the same issues have you resolved yet?
Avatar for Simonjj7
Re: Mini box
No it's still not working
Re: Mini box
If you getting an mr001 error try below:- I was getting it and I followed the below and it works now.
Assume the mini came from Sky and you have the monthly Q Multiscreen subscription?
Reboot the mini as above.
if you need to reset your remote google ut and it will tell you how to do it. 🙂
Re: Mini box
Does the home button work to bring up the menu?
edit: ah sounds like not. Hold down 7&9 on the remote to see if it starts the setup/pairing process.
Avatar for Simonjj7
Re: Mini box
No unfortunately not
