Discussion topic: Mini box
This message was authored by Pam+and+Mike This message was authored by: Pam+and+Mike
Mini box
My mini box was switched off at the wall. It now won't work! Won't connect to the router despite entering my Wi-Fi info. I've rebooted the router and still no luck. Help!
This message was authored by Laing1 This message was authored by: Laing1
Re: Mini box
@Pam+and+Mike who is your broadband provider ?  If its Sky then the mini boxes connect by using the WPS button, If its a third party provider then your mini boxes wont connect direct to the router by wifi you need to connect the mini boxes to the main box by way of the Sky mesh and the WPS button
Re: Mini box
Hi @Pam+and+Mike
Reboot the minis as above.
If the minis still do not connect try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
