This discussion topic has been answered Discussion topic: Mini box wont connect at all.
Message posted on 08 Apr 2024 02:36 PM
Well, I have tried calling sky customer services and it's impossible to speak to anyone. I tried to book an engineer online but again system is down.
i have tried to reconnect my mini box which is anout 7yrs old all to no avail. I get several codes pop up mainly MR102 but missed the others. It wont connect to the router or to the Qbox downstairs and its driving me insane and to think of the money i spend each month.
Message posted on 08 Apr 2024 03:45 PM
Hi @JohnLeda
Reboot the mini as above.
Hi @JohnLeda
