Discussion topic: Mini box won’t turn on
Message posted on 02 Jul 2023 11:35 AM
Mini box won't turn on
Message posted on 02 Jul 2023 11:40 AM
Re: Mini box won’t turn on
Hi @Doddy53
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 02 Jul 2023 04:26 PM
Sorted. Thanks
