Discussion topic: Mini box won’t connect
This message was authored by: Nicola226
Had fibre broadband put in WiFi and connectivity on mini boxes keeps dropping and won't reconnect
Re: Mini box won’t connect
Hi @Nicola226
Reboot the mini as above.
