Discussion topic: Mini box stuck on standby
This message was authored by: Lucie13
Mini box stuck on standby and remote not working  need to order replacement
Re: Mini box stuck on standby
Firstvollow the advice here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
If that does not help, on the second page of the article above, you can order a replacement mini online
@Lucie13 does the mini box come on if you press the amber button ? if it does then the box is fine and its a remote problem
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
