Discussion topic: Mini box states technical fault
This message was authored by: KeithSydee
Sky mini box shows technical fault. I have rebooted and it connects to internet and sky Q box. It shows list of programs that have been recorded but will not play them or display TV channels
Re: Mini box states technical fault
Hi @KeithSydee
Reboot the mini as above.
This message was authored by: Malvern+Michael
Tried all of the above mini still shows technical fault on all channels
This message was authored by: caroline26
hi Malvern+micheal
did you get it sorted ? as i'm experiencing the same thing ! it's so annoying as i can't watch anything i've recorded
This message was authored by: JohnBar
I keep getting the same problem. Getting fed up with it now
This message was authored by: NHS-HW
I've been having this randomly over the past few months, starts in the afternoon about 3pm and last for about 10-12 hours, I've even unplugged and powered off the sky boxes, reset & rebooted router, both vm and bt as I have 1 for work, then plugged in and powered on the main sky box and waited 10 mins then powered on 1 akyq mini, waited 10 mins then the other mini, and within an hour the same erro appears. Getting well annoying now,
This message was authored by: Cbuck1
I have got the same thing.. has any one manage to fix it?
This message was authored by: NicNacNoo10
I have been experiencing the same issues. Can work ok for a few days then back to technical fault.  Sky engineer, last Thursday, on their 2nd visit replaced main sky q box and one of the mini boxes as they weren't displaying correctly on their scans, all was working ok for a few days then yesterday technical fault again!!! Has anyone had this problem resolved?
This message was authored by: Petec76
One of our mini boxes started doing this yesterday (2/2/24) have rebooted the main box and trued several times rebooting the mini box but still not working got to wonder if its a software update issue, currently waiting for update to download and install on main box though doesn't give a status on how long it's going to be.
This message was authored by: derekclarke03
I have had this issue for years. Engineers come out replace both boxes, wire them up with Ethernet cable but always days or weeks later same issue.
i have had nothing on my mini box for over a month now.
I do factory reset on box boxes too and still get nothing.
once contract is up guess it's time to stream from a firestick
We are the People
This message was authored by: Guest.
Another one that has minibox getting a technicial fault, can watch fine at times then it triggers.
Film channels have also pixilated at times but other channels fine.
Mini connects via WiFi
Rebooting main box works for a while
Software version Q270.000.08.00L (5U093C0)
Would not surprise me e if there is a bug in software causing this
Thanks for your replies.  I never did get the mini box problem resolved, so I gave up on Sky, once my contract was up.
This message was authored by: KrazyKat2
I have three Sky Q mini boxes and only one started with the "Technical fault" message. Sometimes it works again the next day. All are connected via ethernet to the fibre router. I have tried all of the solutions suggested including forcing a software download. Makes no difference. Anyone any idea where the fault lies, is it the main box or is it the mini?
In the end an engineer had to come out and replace the main Q box ours was a first gen and had it for many years the HD had cooked its self and was causing the issue. Everything worked fine again when new box was installed.
Thank you. Will try to contact Sky tomorrow. My boxes are probably the first iteration.
