Discussion topic: Mini box remote priblems
This message was authored by: Nicky+Willis
My Q mini box remote won't work , batteries changed , volume ok but nothing else so unable to connect to Main Q box
Re: Mini box remote priblems
Would suggest repairing your Sky q remote.
Pair the remote as in section 3 of this Sky q help article;
https://www.sky.com/help/articles/fix-remote
Hi @Nicky+Willis  If @lettice  suggestion doesn't work, try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, then do the same with the Mini box?
