Discussion topic: Mini box question
Message posted on 08 Aug 2024 03:17 PM
Mini box question
Does the mini box get its signal straight from the wireless router or is it connected to the main Q box ?
This is supposedly different when you don't have Sky as the ISP - We use TalkTalk....
Message posted on 08 Aug 2024 03:19 PM
Re: Mini box question
And if so - why do we lose the use of the minibox when the router is turned off ?
but the main Q box remains working ?
Message posted on 08 Aug 2024 03:30 PM - last edited: 08 Aug 2024 03:31 PM
hi @Wibbly-Woo
When your home wifi is not SKY then the minis connect to the main box using a wifi Signal that SKY Q main box generates and not your home wifi.
To answer your second question - it also relies on your router providing an ip address (via the main box) so it needs the router on as well
