Discussion topic: Mini box order
This message was authored by: Mecca9776
Mini box order
How can i cancel replacement mini box on line as its not needed
Re: Mini box order
@Mecca9776
You will need to call Sky to cancel the order.
You can call Sky free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
