Discussion topic: Mini box not working
Message posted on 24 Jan 2025 06:00 PM
My Sky mini box which I've had for years won't allow me to watch anything and has come up with a message :- "please check your subscription entitles you to view this channel on this box". (I haven't changed my subscription for years and it's working on the main TV on the main Sky Q box). Any ideas please ?
Message posted on 24 Jan 2025 06:17 PM
Re: Mini box not working
@IainM2025 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 24 Jan 2025 06:43 PM
Hi @IainM2025
Reboot the mini as above.
Failing all of the above
