3
This discussion topic has been answered Discussion topic: Mini box not working
This message was authored by: Anmari
Have changed isp and trying to connect my mini box to it but am stuck on Accessibility screen. No matter how many times I switch it off at wall and also try the WPS button
Re: Mini box not working
@Anmari
Sky have suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the telly.
@Anmari
Avatar for Anmari
Level 0 icon
Thank you. You are amazing. All sorted.
This message was authored by: Freelind
Thankyou I followed your instructions and managed to get the accessibility message off screen and my remote working . Sky Q box says I can view on mini box but I can't get past the green and the  flashing orange light on stage 2 of 4- it doesn't move on.  Sky Q box is working and settings says everything is connected but I am not able to get minibox working. Can you help please?
