Discussion topic: Mini box not working
This message was authored by: Janice64
Upgraded to fibre this morning, main tv and sky q working fine. 2 tv with sky mini box upstairs not working at all, any help please?
Re: Mini box not working
@Janice64 Have you tried rebooting your main Q box ie
then
reboot your mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Janice64
Try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
