Discussion topic: Mini box not working
Message posted on 13 Apr 2024 07:41 PM
Any room mini box not working
Message posted on 13 Apr 2024 08:03 PM
Re: Mini box not working
Hi @Lamb-John
Reboot the mini as above.
