Discussion topic: Mini box not working
This message was authored by: Robert055
Mini box will not start up.
Unable to get the green light to come on.
Avatar for Robert055
Re: Mini box not working
Mini box not getting green light on the front
have switched off and on
all internet connections are positive.
have tryed to teset but not working.
Hi @Robert055
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
