This discussion topic has been answered Discussion topic: Mini box not working
Message posted on 02 Mar 2024 01:41 PM
No signal getting to box from main box
Message posted on 02 Mar 2024 01:45 PM
@Roy15 Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
then
Message posted on 02 Mar 2024 01:48 PM
Re: Mini box not working
I've tried rebooting upstairs I'll try main box thank you
Message posted on 15 Jun 2024 10:31 AM
Red light only comes on once I press reset and nothing happens after that.
Message posted on 15 Jun 2024 10:41 AM
I have tried everything, when I switch off and turn back on no light on front only when I press the reset the red light appears and stays on regardless.
Message posted on 15 Jun 2024 12:30 PM
I had this a few weeks ago - left the mini unplugged overnight (not sure this helped to be honest) and then plugged it back in and re-paired the remote control. Press 7 and 9 together on the remote until it flashes 4 times and then point the remote at the mini and press 1 and 3 until the led flashes and they try pressin ghome to see if the mini turns on.
Message posted on 22 Jul 2024 04:50 PM
Red light just stays on
Message posted on 22 Jul 2024 05:06 PM
Thanks up and running 😊👍
