Discussion topic: Mini box not working
Message posted on 08 Nov 2023 12:35 PM
Sky mini box located in bedroom keeps freezing and stops working, this now occurs every time we use it
Message posted on 08 Nov 2023 12:40 PM
Re: Mini box not working
Hi @ACFT
Reboot the mini as above.
Message posted on 09 Nov 2023 07:53 AM
Tried all the above, sometimes the mini sky box stops working multiple times in one evening, the router is in the room below the bedroom, circa 7m away
