Discussion topic: Mini box not working
Message posted on 10 Sep 2023 09:45 AM
Hi can't get mini box to work
Message posted on 10 Sep 2023 09:52 AM
Re: Mini box not working
@Ian+longbottom For the forum to begin to help you'll need to provide a lot more info.
Whats happening with the mini box, any error messages?
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
