Discussion topic: Mini box not working
This message was authored by: Sandbanks+7
Mini box won't connect to router. Main q
box and other mini boxes are connected and working
Re: Mini box not working
Hi @Sandbanks+7
First try rebooting the main Q box and then when this is completely back up and running reboot the problem mini.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically ).
If one of the connected minis is nearer than the main Q box then you can use this for WPS.
If you are on Sky Broadband and the Router is nearer to the mini than the main box or the other minis then you can try pressing WPS on the router instead of the main Q box.
You have 2 minutes after carrying out the Network reset to press the WPS button on the nearest Q device
