Discussion topic: Mini box not working
Message posted on 25 May 2024 06:01 PM
Sky Q box disconnected from the router so I reconnected it then the mini box stopped working. Tried setting up spare new mini box and the same happened both do not want to connect to Q box
error: MR104
Message posted on 25 May 2024 06:06 PM
Re: Mini box not working
Where was the 'spare' mini box sourced from?
Message posted on 25 May 2024 06:08 PM
It was a brand new one from sky never used for another room . Tried 2 mini boxes the one stopped working then tried the spare both won't connect
Message posted on 25 May 2024 06:10 PM
First thing to try is a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Message posted on 25 May 2024 06:12 PM
if you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
Next try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 25 May 2024 06:47 PM
Thanks really appreciate that
