Discussion topic: Mini box not working or remote error MR108
This message was authored by: Barry591
Got Error MR108 remote now also does not work so can't alter from is this first time I'm stuck there
Re: Mini box not working or remote error MR108
Hi @Barry591
Press and hold 7 & 9 together on the remote to set it to infrared mode.  This will then work your Q box but it will mean the remote needs line of sight.
If you can get the box working you can then re pair the remote..
With the Q box on with green make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Avatar for Barry591
@oldfella @Thank you @Laing1 assisted in this and I've now got it up and running thank you.
Both of you gave excellent advice 👍
