Discussion topic: Mini box not responding to remote
Message posted on 29 Dec 2023 03:06 PM
Mini box not working. Tried resetting but when the set up starts it will not respond to the remote on step 1
Message posted on 29 Dec 2023 03:50 PM
Re: Mini box not responding to remote
Hi @Nads1
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
