Discussion topic: Mini box not displaying any broadcast
This message was authored by Tony1956 This message was authored by: Tony1956
Re: Mini box not displaying any broadcast
Hi @Tony1956
Reboot the mini as above.
Hi @Tony1956
No need to start duplicate posts for the same issue.
Your second post has been removed.
